Doug Rucker Posted December 28, 2019 Report Posted December 28, 2019 Here is an awesome surface cleaner we have on sale through January 16th 2020 for 235$ plus shipping. Great surface cleaner for 235$. I was impressed with how well this cleaned using my 5GPM 3500 PSI machine...even if it only last a year or so, you will have gotten your moneys wort...but I'm pretty confident you'll get longer than that. Surface Cleaner 18" Poly Floater HPC #RS6196 The 18” poly version comes as a floater we do offer an optional caster / bracket kit for it (#RS6199 @ $19.57 per set of 4) The handle on the poly model is powder coated steel Rated up to 8 GPM @ 4000 PSI / 212º F Two nozzle spray arm w 2#25025 nozzles Quote
Doug Rucker Posted April 8, 2022 Author Report Posted April 8, 2022 Here is an awesome surface cleaner we have on sale through January 16th 2020 for 235$ plus shipping. Great surface cleaner for 235$. I was impressed with how well this cleaned using my 5GPM 3500 PSI machine...even if it only last a year or so, you will have gotten your moneys wort...but I'm pretty confident you'll get longer than that. Surface Cleaner 18" Poly Floater HPC #RS6196 The 18” poly version comes as a floater we do offer an optional caster / bracket kit for it (#RS6199 @ $19.57 per set of 4) The handle on the poly model is powder coated steel Rated up to 8 GPM @ 4000 PSI / 212º F Two nozzle spray arm w 2#25025 nozzles Old post just testing Sent from my iPhone using Doug Rucker's Pressure Cleaning School mobile app Quote
