Posted
Whenever you have to install bulk head fittings in a tank, you always have to drill a hole using a hole saw.  The plastic shavings will drop into the tank and if you don't vacuum them out them you could get them into your pump causing damage.  Here's a little tip and trick for Keeping Plastic Shavings Out of Your tank.
Guest
Reply to this topic...
